April 11, 2025 at 12:19 pm
b.claudet
SubscriberI am trying to create a customized mixture in ansys fluent using species transport but i am unable to figure how to add gazes to my mixture. I take for instance the methane air mixture containing CO2,H2O, N2, O2 and CH4, and i want to add CO and C2H4 to the mixture. Is this doable and if so what is the method to use?
Thank you for any help or response
April 11, 2025 at 12:47 pm
Forum ModeratorIt is. Copy the additional species from the database and then edit the mixture. Note, you may need to adjust both species and mixture properties to suit your model and always check values as the reference temperature & pressure may not be suitable.Â
Ansys Innovation Space
965
851
599
591
