November 22, 2023 at 10:54 pm
Noah
SubscriberHello,
I have tried to simulate the crash behavior of crash boxes under different temperatures.
I am using the material model MAT_015. Unfortunately, the simulation does not show any significant differences between the different temperatures (in contrast to previous tests).
For the thermal analysis I use
- INITIAL TEMPERATURE
- CONTROL_THERMAL_SOLVER
- CONTROL_SOLUTION
- CONTROL_THERMAL_TIMESTEP
- T01_THERMAL_ISOTROPICKEYWORDS
*CONTROL_SOLUTION
$#   soln    nlq   isnan   lcint   lcacc   ncdcf   nocop   Â
     2     0     0    100     0     1     0
*CONTROL_THERMAL_SOLVER
$#  atype   ptype   solver     -    gpt   eqheat   fwork    sbc
     1     0     11          8    1.0    1.0    0.0
*CONTROL_THERMAL_TIMESTEP
$#    ts    tip    its    tmin    tmax   dtemp    tscp    lcts
     0    0.5   0.001    0.0    0.0    1.0    0.5     0*MAT_THERMAL_ISOTROPIC
$#   tmid     ro   tgrlc   tgmult    tlat    hlat  Â
     1    0.0    0.0    0.0    0.0    0.0
$#    hc     tc Â
5.000000E8 Â Â 0.0162*INITIAL_TEMPERATURE_SET
$#   nsid    temp    loc  Â
     1   260.0     0Why does it show no differences when I change the INITIAL_TEMPERATURE?
Am I using the wrong solver? Or the wrong T01 model?Regards
Noah -
November 27, 2023 at 5:07 pm
Jim Day
Ansys EmployeeÂ
Set NEIPH=5 (if solids) or NEIPS=5 (if shells) in *DATABASE_EXTENT_BINARY to write out 5 extra history variables. The 5th such variable for MAT_015 is T – Troom.  Check the value of that variable to confirm its initial value is the initial temperature per *INITIAL_TEMPERATURE minus TR in *MAT_015.
- The topic ‘Crashbox under different temperatures’ is closed to new replies.
5674
1890
1419
1304
