Coupling Analysis of Heat and Electricity
    • q86121032
      I want to simulate a thermoelectric cooler with a size of about 5 cm*5 cm and a thickness of about 1 nm.
      Is there any suitable solver in Ansys that can solve my problem?
      If so, can you give me some examples?
    • Deepak
      You can use a Thermal-Electric module to carry out coupled analysis.
      Thanks,
      Deepak
    • q86121032
       I have used this module, but because my scale in the thickness direction is too small (1 nm), I cannot use it for simulations.
      Do you have any other suggestions?
      Thanks,
      • ErKo
        Hi
        As many of us have said these are the only modules and elements (sold226) that you can use.
        Erik
  • The topic ‘Coupling Analysis of Heat and Electricity’ is closed to new replies.
