January 10, 2019 at 6:08 am
ashiadarsh
SubscriberHi All,
How can I go for a coupled simulation in ANSYS FLUENT? I have to simulate compressible flow in one part of the domain and Incompressible flow in other part separated by a solid wall..The physics and numerical methods in the two domain is entirely different..Is it possible to simulate two different physics together.
Thanking You,
Adarsh
January 10, 2019 at 11:34 am
Forum ModeratorYou can't model using two different solvers. However, how compressible are the materials? Pressure Based Coupled Solver may be sufficient.
January 10, 2019 at 6:20 pm
cfd_learner
SubscriberWhat I understand, you would like to solve different density materials. You can try with two fluid zones and give them their corresponding density (ideal gas and constant/incomp. ideal gas respectively). Try and let us know.
January 11, 2019 at 4:16 am
January 11, 2019 at 4:22 am
ashiadarsh
SubscriberComputational domain will be sector of 360 deg. consisting of gas domain,solid domain & the coolant(liquid) domain.Gas domain is highly compressible while the coolant domain is Incompressible. In this case whether a coupled formulation is possible?
Usual approach to such problems is first to solve the gas domain independently and impose the boundary condition(the results obtained from the gas domain) on (SOLID+FLUID) thus solving the conjugate heat transfer problem.
I would like to know instead of that,if we can solve for all the three domains simultaneously?
Adarsh
January 11, 2019 at 11:53 am
Forum ModeratorWhat density range do you see over the gas phase: if it's a heat exchanger I wouldn't expect much of a pressure loss, so all the density change is likely to be temperature related.
January 15, 2019 at 3:34 am
ashiadarsh
SubscriberThis is not an heat exchanger...compressible flow is through a convergent-divergent nozzle
January 16, 2019 at 11:48 am
Forum ModeratorWith a separate jacket? Please can you put a better image of the whole domain up?
- The topic ‘Coupled Flow Simulation’ is closed to new replies.
4904
1587
1386
1242
