October 18, 2021 at 9:34 pm
Kasrasoli
SubscriberHow I can process a problem with the
Ansys Fluent model and then bring all the pressures as the initial pressure inside my solid in static structure?
Consider that we have the same model for the solid. Just we need these pressures as the initial pressure...
October 19, 2021 at 12:51 pmKarthik Remella
AdministratorHello I'm not sure if I understand your question fully. Are you trying to use the obtained pressure values in Fluent as forces (loads) for your Mechanical simulation?
Karthik
October 19, 2021 at 3:34 pmKasrasoli
Exactly. I want to consider obtained pressure in the Fluent as an initial pressure for my Mechanical Simulation.
October 20, 2021 at 1:04 amOctober 20, 2021 at 3:25 pmViewing 4 reply threads- The topic ‘Couple a Fluid analysis with a Solid one’ is closed to new replies.
5874
1306
