September 5, 2024 at 1:56 pm
m.shankar03
Subscriberi downloaded the Ansys student from the ansys website. ii followed the guidelines and installed the application. the installation was successful. i then restarted my computer as stated and still cannot find the application.
there is an install.err file found in my program file.
i have deleted and tried installing agian but it keeps happening again.
please help, need this software urgently.
September 6, 2024 at 1:33 pm
josephgerges010
Subscriberdid you find the answer ?Â
i have the same problem.
September 9, 2024 at 9:34 am
Rajeshwari Jadhav
Forum ModeratorHi,
Can you verify if Ansys Student folder present under (C:\Program Files\ANSYS Inc\ANSYS Student).
Share the screenshot of your install.err file.
Did you try to change the path and install it?
September 9, 2024 at 9:36 am
Rajeshwari Jadhav
Forum ModeratorIf you have the Ansys Student folder, here is the path to launch workbench C:\Program Files\ANSYS Inc\ANSYS Student\v2xx\Framework\bin\Win64\RunWB2.exe
September 12, 2024 at 1:25 pm
dceri
SubscriberHi, good morning
I have the same issue as m.shankar03 and josephgerges010
Even after flollowing guidelines (administrator permissions, etc) and trying install more than once, the applicaton doesn´t install propoerly. and there is a install.err file and is not possible to find the application to launch the workbench in the apps list.
@Rajeshwari Jadhav thanks, I tried the path C:\Program Files\ANSYS Inc\ANSYS Student\v2xx\Framework\bin\Win64\RunWB2.exe you mentioned,
and you are right, there is an icon there, but doesn´t run the application.
theres is an error mesage after running that icon
seems strange
September 12, 2024 at 1:30 pm
Rajeshwari Jadhav
Forum ModeratorHi,
Please share the screenshot of error.
September 12, 2024 at 1:39 pm
September 12, 2024 at 1:55 pm
Rajeshwari Jadhav
Forum ModeratorHi,
May I know which OS you are using?
September 12, 2024 at 2:07 pm
dceri
SubscriberOk seems that you found the root ,
I´m using Windows 11 64bit, and at Requirements you are asking for Windows 10 64 bit.Â
my mistake then. could that be the problem? thought that later versions didn´t matterÂ-
September 12, 2024 at 2:55 pm
dceri
SubscriberJust to finally check Mr. @Rajeshwari Jadhav: my problem is the Windows 11 OS i´m currently using? or should I wait for another kind suggestion from your side?
thanks in advance.
September 12, 2024 at 2:59 pm
Rajeshwari Jadhav
Forum ModeratorWindows 11 is supported. do you have any other versions installed too?
September 12, 2024 at 3:26 pm
dceri
SubscriberI have version 11 updated from 10.
Sorry for not having any other useful info, I was interested to solve it since I saw there were more students like me with the same issue.other option I have is install in another computer, but this one had a suitable graphic card.Â
October 4, 2024 at 5:21 am
mukund.gayakhe
5729
