Ansys Products
Ansys Products
Could not connect to license server: 59757@localhost. The host is invalid
    • anant
      I have installed student version of ansys workbench. But everything I try to open it I get this error. I earlier installed cracked version of ansys but then deleted it instead of uninstalling it. Is that causing this problem or something else? Please help.
      TIA
      Uninstall the Student version, then uninstall ALL ANSYS tools & licence managers: if you deleted some you may have stray files/registry entries. You also need to find & remove the %appdata% for both ANSYS and SpaceClaim.  Then put the Student version back on.
    • tsiriaks
      Aside from what Rob's mentioned, please also check your environment variables.
      Open CMD Prompt, type 'set' (without quote ' ') .
      Post the output of it here.
      Thanks,
      Win
    • ayushagw
      when i am opening in geometry SpaceClaim i m getting an error "Not connected to a local license server for ACLE actions"
  • The topic ‘Could not connect to license server: 59757@localhost. The host is invalid’ is closed to new replies.
