October 3, 2018 at 4:51 pmKessaSubscriber
Hi there,
I doing a transient simulation in Ansys Maxwell for a stator with a winding having four identical coils in series. And this winding is excited with voltage source, so the voltage on those four coils are expected to be same as a quarter of the total input voltage. In my simulation results, if I do not check the 'Consider core loss on fields', the results are good, and voltage drop on four coils are the same with each other. But if I check that button, the voltage drop on the first coil would be much lower than others.
In my understanding, when we check that option, we are making our simulation more accurate by estimating the core loss and modify the field results. But why there is a change in the voltage distribution? I thought the changes for all four coils would be the same.
I would appreciate it very much if anyone can figure this out.
Best,
Kessa
February 7, 2021 at 3:04 amvigorSubscriberhi, how to understand Consider core loss on fields? Which parameters are affected? thank you!Arrayn
February 8, 2021 at 12:24 pmNavya CAnsys EmployeeHi @vigor nYou can find the explanation for this in Maxwell help.nRefer to Setting Core Loss for Transient and Eddy Current Solvers section in maxwell help for more details.nnRegardsnNavyan
- The topic ‘Core loss effects on Transient simulations’ is closed to new replies.
- HFSS Incident Plane Wave excitement mode
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- On-chip inductor design
- Maxwell circuit – PWM
1416
599
591
565
366
