June 5, 2020 at 7:42 pm
Spencejo
SubscriberHi all,
I am trying to convert a whole solid body model I have into a volume. So far, I have been unable to generate this using the Volume Extract tool and have only made partial sections of it into a volume. Is there a way to simply convert the entire geometry into a volume? I'll attach an image of the model to this post. Thanks!
-SpencerÂ
June 6, 2020 at 3:53 am
Kalyan Goparaju
Ansys EmployeeHello Spencer,Â
Can you please insert the image into your post instead of adding it as an attachment?Â
Thank you,
Kalyan
June 6, 2020 at 3:54 am
June 8, 2020 at 1:27 pm
Kalyan Goparaju
If the solid body itself is the geometry that you want to use for the CFD simulation, then just directly import .scdoc file into the appropriate meshing software and continue the process. Volume extraction is only required when the solid body you have makes up only the boundaries/walls of your geometry and your fluid domain needs to be extracted based on these walls.Â
Thanks,
Kalyan
June 8, 2020 at 5:39 pm
Spencejo
SubscriberHi Kalyan,
That is indeed the case with this solid, I imported it as you said and it worked! Thank you very much.
-SpencerÂ
June 8, 2020 at 6:57 pm
Kalyan Goparaju
I am glad it helped. Can you please mark the answer as 'Is Solution' so that it can help others.Â
Thank you,Â
Kalyan
- The topic ‘Convert Entire Solid Body to Volume in Spaceclaim’ is closed to new replies.
6625
1311
.jpg?width=690&upscale=false)
