Photonics
Photonics
Convergence in Charge simulation
    • basma.eldosouky
      Hello everyone,
       I am trying to model an OLED using Charge, when running the project, I get this error: there was an unknown parallel error. The error code is 9010, the process number is 0. I am trying to fix this issue according to this link https: //optics.ansys.com/hc/en-us/articles/8355464963987-Troubleshooting-convergence-errors-in-CHARGE
      But I still have the same problem. can anyone help me?
    • Dev
      Hello Basma,
      Can you please share a screenshot?
      Additionally, like you mentioned having a well-adjusted mesh across the simulation region is important. More specifically, that the mesh is able to resolve the smallest features of the simulation while allowing for larger mesh size in other areas, to reduce total simulation time. I also suggest examining your voltage boundary condition settings.
      Thanks and regards
      Devika
    • basma.eldosouky
      Dear Devila,
      Thanks a lot for your reply. This is the first time using the charge, I built an OLED structure of Al(100nm)/Lif(1nm)/Alq3(60nm)/NPB(75 nm)/glass(1.5um). I also entered only some properties of the materials like Eg, permittivity, and workflow, as I have trouble finding the electronic properties of these materials.  I set the global mesh setting of the charge solver with a min edge length of 0.001 um and a max edge length of 2 um, as shown in the following figures.
    • basma.eldosouky
    • basma.eldosouky
    • basma.eldosouky
    • Dev
      Hello Basma, Thank you for sharing more details: which version of software are you using? You can find the details in About page:
    • basma.eldosouky
      Hello Devika, I use release 2023 R1 , version 7.11.3262.
    • Dev
      Hello Basma,
      New version is released can you ty updating the software to 2023 R2.3 and running the simulation?
      Customer Downloads (lumerical.com)
Viewing 8 reply threads
  • The topic ‘Convergence in Charge simulation’ is closed to new replies.
