May 16, 2024 at 7:49 am
Zhuolin Zhao
SubscriberI use the Harmonic balance method to solve a turbine. But this runninig seems not to stop.Â
Like the situation in the picture, I set the convergence criteria RMS to 1e-4, and add user interrupt condition,Cov to 1e-5,and there is also a max iterations.
And corresbonding to the result in Solver manager, it should already stop. Do you have any Idea about the reason and the solution?
Thanks
May 17, 2024 at 4:38 pm
rfblumen
Ansys EmployeeThe Interrupt Control Option is set to "All Interrupts". This means that not only the residual target must be met (along with a conservation target if set) but also all user interrupt conditions. There is a user interrupt condition, Iterations, that isn't being shown in your screenshots. I would check that to make sure that condition is also met.
May 19, 2024 at 8:20 am
Zhuolin Zhao
SubscriberThanks for your reply, iterations condition is just larger than 100, I check several times to make sure all the conditions are met. I would like to ask if there are strict rules for the grammar of this expression? Thanks
May 20, 2024 at 3:50 am
rfblumen
Ansys EmployeeCEL does follow certain rules concerning syntax. Since there is no screenshot of the expression used for Iterations I can't comment on that.
May 21, 2024 at 7:18 am
May 21, 2024 at 3:20 pm
rfblumen
Ansys EmployeeAlthough for a steady-state run it should be equivalent, please try atstep (Accumulated Time Step) instead of aitern for the Iterations interrupt condition.
- The topic ‘convergence criteria and user interrupt condition didn’t work’ is closed to new replies.
6269
