Electronics
Electronics
Convergence and Adaptive Mesh Refinement on PostProcessed Data
    • akizuki_kaho
      Similar to this issue in HFSS 3D
      How to create Output Variables and setup convergence criteria based on output variables in HFSS 3D Layout ?
      Can I use an output variable, especially peak gain or gain in a certain direction (far-field), as the convergence criteria in HFSS?
      I did not find the "advanced>>" bottom is the "driven solution setup" page
    • dushyant.marathe
      Hi Akizuki,
      In HFSS, you can add the convergence based on peak gain, output variables or any other quantity.
      To do so, go to 'Setup' inside project Manager. This should open a Driven Solution Setup dialog. Click on 'Expression Cache' button.
      Then you click Add... to add a desired quantity in convergence
      Else please refer the HFSS help PDF and section titled "Specifying Expressions for Adaptive Convergence"
      Thanks,
