October 23, 2023 at 12:56 pm
ALEX
SubscriberCould somebody point on how to make contacts between a shell body surface and solid beam elements? In the contact tool command, it says that my contacts are inactive and i do not understand why..
Thanks in advance,
October 23, 2023 at 2:28 pm
Akshay Maniyar
Ansys EmployeeHi Alex,
Can you share some images so that it will be easy to understand the issue?
Thanks,
Akshay Maniyar
October 23, 2023 at 3:13 pm
October 23, 2023 at 3:16 pm
October 23, 2023 at 3:17 pm
ALEX
SubscriberI want bonded type of contact between surface body and beam element and aditionally bonded contact between two beam elements.
October 23, 2023 at 4:01 pm
Ankush Choudhary
Ansys EmployeeÂ
Hi Alex,
We can directly create the bonded contacts. You may try using the MPC formulation. Have you run the analysis after creating the contacts? Did you get rigid body motion during the simulation?
October 23, 2023 at 4:13 pm
October 23, 2023 at 4:36 pm
Ankush Choudhary
Please check out the post below related to these warnings.
- The topic ‘CONTACTS BETWEEN SHELL AND SOLID BEAM’ is closed to new replies.
5824
