October 26, 2023 at 7:47 pm
Jacob Ellis
SubscriberI have two blocks touching each other. I am trying to keep them bonded using *CONTACT_AUTOMATIC_SINGLE_SURFACE_TIED while displacing one side of block A and block B has one side fixed.Â
To me, this seems like a simple problem that should work for this contact. I can accomplish this with other contacts. From the definition of CLOSE, if set to zero it uses a default value that should capture the nodes of the other surface. My contact definition using the keyword manager in 2023R2 is below.
October 27, 2023 at 6:10 pm
Chris Quan
Ansys EmployeeThe Slave Segment Set is defined in the Keyword. However, the Master Segment Set is not defined.Â
So if the Block A is the moving part, the face on the Block A can be defined as the geometry in the Master Segment Set, while the face on the Block B can be defined as the geometry in the Slave Segment Set.
October 27, 2023 at 9:41 pm
Jacob Ellis
SubscriberHi Chris, thanks for your comment. This is a single surface contact type. Master surface is not needed. For a sanity check I tried it anyways and it gives an error telling me so.Â
October 27, 2023 at 9:50 pm
Chris Quan
Ansys EmployeeHi Jacob, sorry, you are right. Single surface contact doesn't need the Master Segment Set. Â
Can you write the input file from WB LS-DYNA GUI and then check the Keyword *CONTACT_AUTOMATIC_SINGLE_SURFACE_TIED to see if it has been written correctly?
October 27, 2023 at 11:51 pm
Jacob Ellis
SubscriberChris, I wrote out the input deck and reviewed it in LS-PrePost. I can't see a single thing wrong with it.Â
One thing to note is that with MPP the solver runs but the blocks separate. With SMP it fails with this error.
Interface 280 references to CID 280 above. It is the only contact definition in the problem. Segment Set 4 is the only segment set defined.Â
October 28, 2023 at 12:30 am
Jacob Ellis
SubscriberBelow is a small example made from scratch in LS-PrePost
====$# LS-DYNA Keyword file created by LS-PrePost(R) V4.10.3-21Apr2023 $# Created on Oct-27-2023 (20:26:28) *KEYWORD *TITLE $# title LS-DYNA keyword deck by LS-PrePost *CONTROL_TERMINATION $# endtim endcyc dtmin endeng endmas nosol 0.01 0 0.0 0.01.000000E8 0 *BOUNDARY_PRESCRIBED_MOTION_SET $# nsid dof vad lcid sf vid death birth 2 1 2 1 -1.0 01.00000E28 0.0 *BOUNDARY_SPC_SET $# nsid cid dofx dofy dofz dofrx dofry dofrz 1 0 1 1 1 1 1 1 *SET_NODE_LIST_TITLE fixed $# sid da1 da2 da3 da4 solver its - 1 0.0 0.0 0.0 0.0MECH 1 $# nid1 nid2 nid3 nid4 nid5 nid6 nid7 nid8 3 6 15 12 9 18 24 21 27 0 0 0 0 0 0 0 *CONTACT_AUTOMATIC_SINGLE_SURFACE_TIED $# cid title $# surfa surfb surfatyp surfbtyp saboxid sbboxid sapr sbpr 1 0 0 0 0 0 0 0 $# fs fd dc vc vdc penchk bt dt 0.0 0.0 0.0 0.0 0.0 0 0.01.00000E20 $# sfsa sfsb sast sbst sfsat sfsbt fsf vsf 1.0 1.0 0.0 0.0 1.0 1.0 1.0 1.0 $# close 0.0 *SET_SEGMENT $# sid da1 da2 da3 da4 solver its - 1 0.0 0.0 0.0 0.0MECH 0 $# n1 n2 n3 n4 a1 a2 a3 a4 30 33 42 39 0.0 0.0 0.0 0.0 33 36 45 42 0.0 0.0 0.0 0.0 39 42 51 48 0.0 0.0 0.0 0.0 42 45 54 51 0.0 0.0 0.0 0.0 *MAT_ELASTIC $# mid ro e pr da db not used 17.83000E-9 207000.0 0.3 0.0 0.0 0.0 *PART $# title boxsolid $# pid secid mid eosid hgid grav adpopt tmid 1 1 1 0 0 0 0 0 *SECTION_SOLID $# secid elform aet unused unused unused cohoff gaskeit 1 1 0 0.0 0.0 *PART $# title boxsolid $# pid secid mid eosid hgid grav adpopt tmid 2 1 1 0 0 0 0 0 *DEFINE_CURVE $# lcid sidr sfa sfo offa offo dattyp lcint 1 0 1.0 1.0 0.0 0.0 0 0 $# a1 o1 0.0 0.0 0.01 1.0 *ELEMENT_SOLID $# eid pid n1 n2 n3 n4 n5 n6 n7 n8 1 1 1 2 5 4 10 11 14 13 2 1 2 3 6 5 11 12 15 14 3 1 4 5 8 7 13 14 17 16 4 1 5 6 9 8 14 15 18 17 5 1 10 11 14 13 19 20 23 22 6 1 11 12 15 14 20 21 24 23 7 1 13 14 17 16 22 23 26 25 8 1 14 15 18 17 23 24 27 26 9 2 28 29 32 31 37 38 41 40 10 2 29 30 33 32 38 39 42 41 11 2 31 32 35 34 40 41 44 43 12 2 32 33 36 35 41 42 45 44 13 2 37 38 41 40 46 47 50 49 14 2 38 39 42 41 47 48 51 50 15 2 40 41 44 43 49 50 53 52 16 2 41 42 45 44 50 51 54 53 *NODE $# nid x y z tc rc 1 100.0 0.0 0.0 0 0 2 150.0 0.0 0.0 0 0 3 200.0 0.0 0.0 0 0 4 100.0 50.0 0.0 0 0 5 150.0 50.0 0.0 0 0 6 200.0 50.0 0.0 0 0 7 100.0 100.0 0.0 0 0 8 150.0 100.0 0.0 0 0 9 200.0 100.0 0.0 0 0 10 100.0 0.0 50.0 0 0 11 150.0 0.0 50.0 0 0 12 200.0 0.0 50.0 0 0 13 100.0 50.0 50.0 0 0 14 150.0 50.0 50.0 0 0 15 200.0 50.0 50.0 0 0 16 100.0 100.0 50.0 0 0 17 150.0 100.0 50.0 0 0 18 200.0 100.0 50.0 0 0 19 100.0 0.0 100.0 0 0 20 150.0 0.0 100.0 0 0 21 200.0 0.0 100.0 0 0 22 100.0 50.0 100.0 0 0 23 150.0 50.0 100.0 0 0 24 200.0 50.0 100.0 0 0 25 100.0 100.0 100.0 0 0 26 150.0 100.0 100.0 0 0 27 200.0 100.0 100.0 0 0 28 0.0 0.0 0.0 0 0 29 50.0 0.0 0.0 0 0 30 100.0 0.0 0.0 0 0 31 0.0 50.0 0.0 0 0 32 50.0 50.0 0.0 0 0 33 100.0 50.0 0.0 0 0 34 0.0 100.0 0.0 0 0 35 50.0 100.0 0.0 0 0 36 100.0 100.0 0.0 0 0 37 0.0 0.0 50.0 0 0 38 50.0 0.0 50.0 0 0 39 100.0 0.0 50.0 0 0 40 0.0 50.0 50.0 0 0 41 50.0 50.0 50.0 0 0 42 100.0 50.0 50.0 0 0 43 0.0 100.0 50.0 0 0 44 50.0 100.0 50.0 0 0 45 100.0 100.0 50.0 0 0 46 0.0 0.0 100.0 0 0 47 50.0 0.0 100.0 0 0 48 100.0 0.0 100.0 0 0 49 0.0 50.0 100.0 0 0 50 50.0 50.0 100.0 0 0 51 100.0 50.0 100.0 0 0 52 0.0 100.0 100.0 0 0 53 50.0 100.0 100.0 0 0 54 100.0 100.0 100.0 0 0 *SET_NODE_LIST_TITLE moving $# sid da1 da2 da3 da4 solver its - 2 0.0 0.0 0.0 0.0MECH 1 $# nid1 nid2 nid3 nid4 nid5 nid6 nid7 nid8 31 28 37 40 34 43 46 49 52 0 0 0 0 0 0 0 *END
October 30, 2023 at 9:38 pm
Chris Quan
Ansys EmployeeIt seems that you have to use MPP to run this model with *CONTACT_AUTOMATIC_SINGLE_SURFACE_TIED.
Also, you need to scope the slave faces to All Faces of the model or Both Faces on their interface. Otherwise it won't be bonded.
Finally, in WB LS-DYNA bonded contacts will be automatically created under Connections after geometry has been imported to Mechanical GUI and the distance between two faces is less than the specified tolerance. It may not be necessary to use Keyword Manager to define bonded contacts. Contact Properties can be inserted to modify the behavior of these bonded contacts such as type, penalty stiffness, etc.Â
- The topic ‘*CONTACT_AUTOMATIC_SINGLE_SURFACE_TIED not bonding’ is closed to new replies.
6785
1331
1147
