January 9, 2025 at 6:28 am
January 9, 2025 at 9:25 am
harshvardhan.negi
Ansys EmployeeHi,
By the "cold bush method" I am assuming that this creates a press fit. If that is the case, then bonded contact can be used.
Please feel free to correct my assumptions if they are incorrect.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)-
January 9, 2025 at 11:28 am
Jeonee
SubscriberIt applies pressure, but when there is too much load, the part can separate. So what if we use friction contact and apply a fixed joint from the front and back?
January 9, 2025 at 11:52 am
harshvardhan.negi
Ansys EmployeeSo how much load is "too much load". If you think that the loads during this simulation can go near the spearation load, then may want to, but otherwise it might not be as helpful. Moreover, frictional contacts are non-linear in nature and may introduce convergance issues.
If you wish to apply fixed joint and frictional contact, then fixed joint will neggate any friction between those 2 parts (Assuming we are applying fixed joints to those parts)
If you wish to accurately model the press fit and the resulting contact pressure, you can refer this video:
https://www.youtube.com/watch?v=5jH2Ox6-YkURegards,
Harshvardhan
Ansys Help
5649
1885
1404
1303
