LS Dyna
LS Dyna
contact between two perpendicular shell plates
    • gangolu
      I am using shell elements for an I section and applying blast loading on its weak axis. I couldnt able to establish proper contact between flange and web. Any suggestions which contact is more suitable!  I tried merging nodes but couldnt achieve good results
    • Jim Day
      I suggest that flange and web share nodes at their juncture even though it means there's some slight overlap of material at that juncture.     *CONTACT_AUTOMATIC_SINGLE_SURFACE would only be needed if deformation were extremely large, such as would occur if the section buckled.
      If that doesn't help, provide an image that illustrates the bad behavior.
  • The topic ‘contact between two perpendicular shell plates’ is closed to new replies.
