February 8, 2024 at 11:09 am
domenech
SubscriberI know I can connect a point mass to a surface by means of flexible or rigid elements, but I don't know how to customize this.
In APDL I can create a keypoint, stick a point mass element to it, and then connect it manually to beam and spring elements. In Workbench I developed a workaorund where I need to create a dummy solid part, connect the point mass to it, and then connect the beam/spring elements to the solid.
Is there a way to avoid the dummy solid? I'd like to create a floating, "clickable" point mass element , and then connect beams and springs to it as if it was a remote point.
Thank you
February 8, 2024 at 1:02 pm
ErKo
Ansys EmployeeHi
Just use a point mass:
https://simutechgroup.com/measuring-force-on-a-point-mass-in-static-and-harmonic-analysis/
https://www.youtube.com/watch?v=bDYBwfK48h0
https://www.youtube.com/watch?v=LTuSRMSty-g
All the best
Erik
February 8, 2024 at 1:07 pm
domenech
SubscriberThank you, Erik
- The topic ‘Workbench: Connecting point mass to solids by means of beam and spring elements’ is closed to new replies.
6455
