May 13, 2024 at 12:22 pm
Alexander Tangen
SubscriberHi,Â
I want to run an analysis where I need to use solid for a detailed analysis, and model the rest of the structure as shells (to save computational cost).
I am aware of using bonded contact, but I want to know if it is possible to share nodes somehow. I use spaceclaim. I have tried to use Workbench -> Share, but it does not include the part between shell and solid. How can I connect a shell and a solid by sharing nodes, not bonded contact?
Thanks.Â
May 13, 2024 at 1:08 pm
erik.kostson
Ansys EmployeeÂ
Hi
This shows how to connect solid and shells:
https://www.youtube.com/watch?v=5RLFIaQVfxw
All the best and hope this helps
Erik
May 13, 2024 at 2:22 pm
Simone.Lucertini
SubscriberContact: Bonded,
Formulation: MPC
select all DOFs if you want to connect also the rotations so the moment.
You can check the moment is properly passing trough the elements, by loocking at the result:
ENMOVECTORS (unaveraged) at the connection. (Must be non-zero)
- The topic ‘Connect solid and shell’ is closed to new replies.
