May 29, 2024 at 9:56 pm
Gabriel Morales
SubscriberHello,
I have HFSS 24r1 installed on a RHEL 8.9 system and I keep seeing the following error when running the ConfigureSoftware.bash script:
> Running first-time configuration...
 - *** Dependency verification test disabled by default ***
  [ Use 'export ANS_DEPCHECK=1 ; ./ConfigureSoftware.bash --fullconfig' ]
 - Retrieving user settings... Done
 - Applying user settings... Done
 - Configuring OCX files... ERROR
 * /app/hfss/hfss24r1/v241/Linux64/controls.ocx : error 3
  > RegSvr32: LoadLibrary("/app/hfss/hfss24r1/v241/Linux64/controls.ocx") failed.
  > GetLastError returns 0x0000007e.ConfigureSoftware.bash failed with errors.
The same version and script appears to work on a RHEL 7.9 system. I am unsure if this is a package/library issue or something else? Any help is appreciated.Â
Thank you,
G -
May 30, 2024 at 12:47 pm
George Karnos
Ansys EmployeePlease ensure you have installed all prerequisites outlined in the installation guides.
2.1. Required Linux Libraries and Packages by Product (ansys.com)ANSYS Electromagnetics Suite Installation Guide Linux
- The topic ‘Configuring OCX files… ERROR – RHEL 8.9’ is closed to new replies.
