TAGGED: ansys-workbench, designmodeler, high-resolution
January 27, 2022 at 3:15 pm
AlexSzatmary
SubscriberI have a 4500x2000 display. Workbench shows some elements at half-size. What's the best way to make Workbench usable?
I'm surprised that high resolution displays are not yet supported. This has been a problem for years. It's a serious issue in educational settings, where students need to configure lab machines and then reverse the change before they sign out.
I have tried overriding resolution using the compatibility tool for Workbench and related executables. I also have tried dropping the overall system resolution to, say, 1920x1080.
January 27, 2022 at 3:37 pmGeorge Karnos
Ansys EmployeeI would recommend trying this to see if it helps:
From Start Menu > ANSYS 2022 R1 > Right click on Workbench 2022 R1 > Open file location >Right click on Workbench 2022 R1 shortcut >Properties > Compatibility >Change highDPIsettings > Override high DPI scaling behavior settings > System (Enhanced) > Apply
Viewing 1 reply thread- The topic ‘Configure high resolution display’ is closed to new replies.
4092
1487
1318
1156
