August 10, 2020 at 6:27 am
veera
Subscriberi am doing ic engine simulation, for that i am using cone injection type in dpm model, in that cone injection setting , how to set x-axis, y-axis and z-axis?
i have the x,y,z co-ordinate values
August 10, 2020 at 12:31 pmAmine Ben Hadj Ali
Ansys EmployeeIt should be the rotational axis of your cone. You should know that nAugust 11, 2020 at 4:06 amveera
SubscriberDear DRamine;n i have x,y, z coordinates with we can find that x, y, z components of vector defining the cone axis?nSeptember 9, 2020 at 3:42 amveera
Subscriberpls tell me sirnSeptember 9, 2020 at 2:17 pmRob
Forum ModeratorIt's the direction of the spray axis. You have a point and vector, ie where the spray starts and which direction it's heading in: you need to work these out. nSeptember 10, 2020 at 9:06 amveera
SubscriberI HAVE THE WHERE THE POINT STARTS , THAT MEANS WITH THAT CO-ORDINATES VALUES , HOW TO FIND THE DIRECTION?nSeptember 10, 2020 at 9:20 amRob
Forum ModeratorIf the injection is parallel to the x-axis the vector would be 1 0 0 if aligned with z it's 0 0 1 You need to decide on the direction vector and then work it out: this is why you did trigonometry at school. nViewing 6 reply threads- The topic ‘cone injection settings’ is closed to new replies.
4858
1587
1386
1242
