March 1, 2024 at 5:31 pm
James Pyland
SubscriberI have a model which I can only get to run by turning on weak springs. The compression only supports are defined on the support holes and are not reporting any reaction at all, like they are not even there. Why would they not pick up any reactions?
March 4, 2024 at 11:26 am
Ashish Khemka
Forum ModeratorHi James,
Can you share the snapshot of the model setup? Also, what if you fix the holes and see the load distribution?
Ashish Khemka
March 4, 2024 at 2:38 pm
March 4, 2024 at 2:46 pm
James Pyland
SubscriberHi Ashish, I've discussed this with the lead engineer. We are changing the boundary conditions to fixed supports. I do not need to persue this any further, thanks.
- The topic ‘Compression only supports not working’ is closed to new replies.
