Compound Cylinder Analysis
    • ianogormanmecheng
      Trying to achieve the correct method of applying boundary conditions/restraints/fixed support for a dual sleeve compound cylinder. Have just fixed it at one end but am not sure if its realistic.
      Also the setup of the contact for the interference. I am not sure if its set up correctly because my hand calculation for the interference pressure does not match.
      Any help is greatly appreciated.
    • jj77
      Not sure what this is exactly, but if it is an interference fit type of model then I would do the following.
      Make the inner cyl. larger as needed.
      Split the geometry so you get one 1/4 model (symmetry).
      Apply symmetry restraints (then no need to fix anything) and solve (do not include offset in the contact).
  • The topic ‘Compound Cylinder Analysis’ is closed to new replies.
