Composite Beam Buckling analysis of two ends simple supported
    • James02dai
      I am doing a composite beam buckling analysis on Ansys. I had difficulties on creating boundary conditions in the two ends of beam. The beam is supported by using simple support. I created the composite beam by shell element. But in the static analysis, I can not apply a simple support on the end. Does anyone know how to solve this issue? Thanks in advance.
    • jj77
      If you can put an inline image to show a bit more details of the structure and what BC you need then it is easier to help.
      If I can guess choose a remote displacement on the edges, where the BC needs to be and fix only the translational dof.
      See this video where they apply a remote force which is similar in the way it is applied (you still need the remote displ.)
      https://www.simutechgroup.com/tips-and-tricks/fea-videos/350-ansys-workbench-tips-tricks-pipe-loading
    • James02dai
      Hi, jj77, Here is the model that I want to model. In the pic, it is a round beam. I want to create a I beam. The boundary condition is show as the pic. I had know idea how to get this for composite beam. As the beam I created is in shell element. I would like to know more on this if you could tell me more. Thanks.
      Use the site Search feature to look for Pinned in the Structural Mechanics category and you will find several discussions on this topic.
      I agree with jj77 to use Remote Displacements.
    • James02dai
      Hi,for composite material, how to get deformed shaped in linear buckling for non-linear analysis? In workbench 19.1, the shape can be directly transferred by linking the solution to the non-linear analysis model(static analysis), but this method does not work for composite material. Can anyone give me an idea? Thanks.
    • jj77
      If it does not work create the imperfection (in cad) as in your image but with a very slight bow something that could be observed in reality.
      Some building codes will advice on the size and shape of column imperfection
      https://advantage.graitec.com/en-US/knowledgebase/article-details/?code=KA-03157
Viewing 5 reply threads
  • The topic ‘Composite Beam Buckling analysis of two ends simple supported’ is closed to new replies.
