Comparing Solid element and Shell element – WB
    • thanhttdt
      Hi everyone,
      When I did an analysis for 2 cases: solid element and shell element in Workbench, I saw that the von Mises in 2 cases are much different
      235 Mpa and 68 Mpa respectively.
      Figure 1: Solid element, VM stress 235 Mpa
      Figure 2: Shell element, von Mises stress 68 Mpa
      Could anyone take a look and send me any explanation?
      Link file: https://drive.google.com/drive/folders/1m5rmXKPJWJT7zMBKs1TlCb9qXxPo6JJX?usp=sharing
      Thanks in advance,
    • thanhttdt
      Could anyone see and give me any suggestions?
      Many thanks,
      Hello Thanhttdt,
      You have applied different loads to the two models.
      On the Solid Model, you have a bearing load, which takes the force and applies it to the nodes only on the side of the face that a pin in the hole would push on, and with the force scaled as a cosine function with 1 on the centerline ramping down to 0 at the 90 degree point of the face.
      On the Shell Model, you have a force load, which takes the force and divides it equally to all nodes around the circle.
      Try putting a force load on the solid model and it will be closer. However, the bearing load is a more realistic load for your case.
      Peter.
    • thanhttdt
      Hi Peteroznewman,
      Thanks for your suggestion,
      I try to use bearing load in shell element model but cannot.
      Could you suggest me to apply bearing in this case?
      Thanks in advance
  • The topic ‘Comparing Solid element and Shell element – WB’ is closed to new replies.
