Embedded Software
Embedded Software
Topics related to SCADE Suite, SCADE Display, SCADE One and more.
Command or tool to extract information about input and output data associated to a specific node
    • Vincent92
      I search how to generate a file contains data (structure and data name) linked to Inputs of Node and know the data connected on the output of Node.
      FOr the moment i performe an analizys on generated code to extract this information. Do you have a command (or procedure ) or tools to perform this export?
    • rahul.kumar
      May I know which Ansys software you are using?
    • Vincent92
      Hello I used scade version 2019,
      Did this answer the question? => No
  • The topic ‘Command or tool to extract information about input and output data associated to a specific node’ is closed to new replies.
