Preprocessing
Preprocessing
Combining sweep method with inflation
    • Johnson
      Hi all,
      I am tried to mesh the flange down below with an hexahedral mesh. After some slicing I got some good results and most of my bodys are sweepable (only the bolt is not). But I would like to add some details with the inflation method and put layers around the bolthole and between the flange contact zones.I am using Ansys student 18.0.
      Thank you for your help
      Johnson
    • tsiriaks
      Hi Johnson,
      Same as the other post. Please post this under Structural Mechanics section.
      Thanks,
      Win
      You need to alter how you add inflation:
      https://www.computationalfluiddynamics.com.au/tips-and-tricks-sweep-meshing-in-ansys/
      covers the approach.
  • The topic ‘Combining sweep method with inflation’ is closed to new replies.
