combine the effect of all load steps in static structural analysis
    • Jigar Patel
      How can the result of the current load step be transferred to the next load step of the linear static structural analysis?
      Let's assume I run the simulation with 6 different load steps. Now I want to transfer the results of load step 1 to load step 2 and so on. In the end I want to get the combined results of all load steps (6 load steps) in single load steps (in the 7th load step).
      I have tried a lot to do this, but I did not get the desired results.
      Could someone please suggest a solution to the problem? Any kind of assistance is appreciated.
    • Aniket Chavan
      If your loads are cumulative, that means if load1 which is applied in step 1 continues in load step 2 it is already combined in load step 2.
      If you are removing load1 in step 2 and other subsequent steps or using multiple static structural systems, then you need to use solution combination.
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_Solution_Combinations.html
      -Aniket
    • Jigar Patel
      Thanks Aniket for your Reply.
      I have combined the all the load steps as following using APDL script. Is this correct method?
      !                See Solving Units in the help system for more information.
      !   Commands inserted into this file will be executed immediately after the ANSYS /POST1 command.
      !   Active UNIT system in Workbench when this object was created:  Metric (mm, kg, N, s, mV, mA)
      !   NOTE:  Any data that requires units (such as mass) is assumed to be in the consistent solver unit system.
      FINISH
      /POST1
      !Transformation of load steps into the load cases
      ! Total number of load steps in the ANSYS Simulation
      NSTEPS = 6
      ! Do this for defining the load steps into load case files
      *DO,i,1,NSTEPS,1
          LCDEF,i,i,1
      *ENDDO
      !Defination of all the load cases. Combined Load Cases = Torque load +  All the parasitic loads
      ! Zeroes the results portion of the database
      LCZERO
      !*****************Addition of the individial load cases resulting in 'Combined Load Case'*********************
      ! Performance of Torque load case
      LCOPER,ADD,1
      ! Performance of Parasitic load cases
      LCOPER,ADD,2            ! Performance of Converter Ballooning
      LCOPER,ADD,3            ! Performance of Axial Load
      LCOPER,ADD,4            ! Performance of Bending Load
      LCOPER,ADD,5            ! Performance of Rotational Velocity Load
      LCOPER,ADD,6            ! Performance of Thermo-mechanical load
      !Combined Load Cases (7) = Torque load case (1) + All the parasitic load case (2 + 3 + 4 + 5 + 6)
      ! Appends results data from the database to the results file
      ! Combines all the above load cases result database as 7th (Combined Load) Load Case
      RAPPND,7,7
      ! Creates a Combined load case by writing results to a load case file
      LCWRITE,7,ALL_COMBINED_LOADS,L7
  • The topic ‘combine the effect of all load steps in static structural analysis’ is closed to new replies.
