December 8, 2022 at 6:54 am
Andi Ko
SubscriberI want to give moment load first. then use it as the initial condition for the next analysis which is displacement load. is anyone have an idea how to do it?
December 8, 2022 at 7:18 am
bhagwantP
Ansys EmployeeHello Andi,
Please check bellow links if it helps:
A transient analysis coupled with a static analysis in Workbench, Mechanical application (ansys.com)
Static coupled Transient Structural analysis (ansys.com)
Thanks
December 8, 2022 at 7:46 am
Andi Ko
Subscriberhi, I'll check it out thank you ^^
December 8, 2022 at 7:58 am
Andi Ko
Subscriberi want to confirm, so is it like in Transient analysis using 3 steps
step 1 : OFF time integration, then apply moment load with time step 0.1s and end time step 1s
step 2 : ON time integration don't apply anything with smaller time step and end time step 2s
step 3 : ON time integration apply the displacement load
is it like this?
December 8, 2022 at 2:40 pm
bhagwantP
Ansys EmployeeYes Correct.
Thanks Erik and Andi.
December 8, 2022 at 9:59 am
ErKo
Ansys EmployeeÂ
Hi
That sounds ok.
So first step is static (no inertia and dynamic effects present)
Second step is to just turn on dynamic and inertia effects (is a dummy step not doing anything else)
Final step to do the dynamics transient analysis, and including inertia and dynamic effects.Â
All the best
Erik
PS:jj77 wrote some good posts in the past
December 9, 2022 at 6:54 am
Andi Ko
Subscriberthank you I will try again according to your suggestion
- The topic ‘Combine static and transient analysis’ is closed to new replies.
6575
1311
