Combine (Merging) tolerance
    • jakub.flak
      Hello, I want to merge my bodies in SpaceClaim that I thought are aligned, however I cannot merge them using Combine Tool. Can I set some tolerance to this operation, maybe using scripting? I am able to perform such operation in other CAD software, that's why I'm asking.
    • CFD_Friend
      Hi Jakub,
      You can check for any clearance using the Clearance tool in the Prepare tab of SpaceClaim. This will show faces that are very near but not touching. After you recognize the bad faces you can use the pull tool to extrude the faces so they come in contact. You can choose the Upto (U) option in the Pull menu to pull any of the faces to the adjacent face on the other body.
  • The topic ‘Combine (Merging) tolerance’ is closed to new replies.
