December 5, 2024 at 6:43 pm
mert.berkman
SubscriberHas anyone seen this error ( error "bad geometry specifier 114x78-0181.") while chaging colors of objects/blocks?
Thanks
December 6, 2024 at 3:04 pm
Iceman
Ansys EmployeeHi Mert, Thanks for your question. What platform are you using? Is that Linux? Also, is this error model specific or happens to all the models? Thanks. -
December 6, 2024 at 5:02 pm
mert.berkman
SubscriberHi,
Windows, happens across different models and oddly sometimes does not happen at all
December 6, 2024 at 8:00 pm
Iceman
Ansys EmployeeCan you narrow it down to which object is causing the error? Is the object CAD?
December 6, 2024 at 8:02 pm
mert.berkman
SubscriberThanks Iceman, any non-CAD regular block
December 6, 2024 at 8:09 pm
Iceman
Ansys EmployeeYou are welcome. That's really strange as primitive blocks are really simple and shouldn't have issue. I have checked internally with my colleagues and no one has seen this error before. It might be required to check the model for this issue, unfortunately, this is beyond the scope of the Ansys employees as we cannot access attachments on the forum. We encourage others participates in the forum to pitch in if they can help.
Also, please check it on a different machine, if the error only happens on your machine, it might be an installtion issue. You may try to reinstall the latest Icepak. Thanks.
5934
1306
