November 2, 2021 at 8:32 am
d.kampouridou
SubscriberHello,
I want to run a co-simulation of HFSS and Circuit. How do I create the connection points in the HFSS model, so I can see them as pins (to connect active elements) in Circuit?
November 2, 2021 at 3:15 pmChinmay Telkikar
I would suggest you to go through "Cosimulation Using Ansys HFSS" course from below link:
/courses/index.php/courses/cosimulation-using-ansys-hfss/
Thanks Chinmay
November 3, 2021 at 8:12 amd.kampouridou
SubscriberHi Chinmay and thanks for your reply, I watched the course however it does not answer my question- I know how to excite a main source in Circuit, however if I want to connect a diode between arbitrary points in an antenna design, how do I define these points?
November 3, 2021 at 2:43 pmChinmay Telkikar
Wherever you want to defineapoint use lumped port at that place.
Thanks Chinmay
November 11, 2021 at 9:58 amd.kampouridou
SubscriberThanks for your reply, I have one more question though; it seems that the addition of lumped ports affects the results of the 3D simulation. How could I eliminate these?
November 17, 2021 at 2:53 pmPraneeth
While simulating with lumped ports to use with circuits, then you may need to use the device resistances as the lumped port resistance.
All the very best.
Viewing 5 reply threads- The topic ‘Circuit and HFSS connection’ is closed to new replies.
4838
1587
1386
1242
