July 20, 2026 at 6:01 pm
dnama20
SubscriberI am trying to simulate the reaction of a nickel oxide particle with hydrogen gas, which forms Ni and water vapor. My question is which particle types should be chosen ? I have chosen multicomponent but not able to define nickel oxide and nickel as solid phase in the particle mixture
July 23, 2026 at 8:52 pm
sjohn
Subscriber I use the multicomponent particle type for liquid droplets containing multiple species. I have not used multicomponent particle type for solid particles, may be combusting is a more suitable particle type. I think it is used for carbon particles. If you use multicomponent particle type, you may need to assign it a mixture material consisting of nickel and nickel oxide but maybe combusting is a better option for your case.
July 24, 2026 at 8:07 am
Channel PartnerThanks sjohn.Â
Moderator comment to OP - multiposting is not appreciated. https://innovationspace.ansys.com/forum/forums/topic/dpm-particle-types-multicomponents/
