Ansys Products
Ansys Products
checking available licenses
    • alitabei
      Is there a command to check the available licenses for different solvers for distributed ANSYS?
      Like if the total license capacity is 100 CPU cores and different people are using different no. of cores, how to check how many CPU cores remain to be used?
      The error in my RSM report is attached.
      thnaks
    • ANSYS_MMadore
      Hello
      You can run this command to see the license status. Adjust for your specific installation path. The same command works for Linux, with the path modified for the install.
      "C:Program FilesAnsys IncShared FilesLicensingwinx64lmutil" lmstat -a -c 1055@linlic.engr.oregonstate.edu
      Thank you,
      Matt
    • alitabei
      thanks
  • The topic ‘checking available licenses’ is closed to new replies.
