December 9, 2021 at 5:59 am
Neda_17
SubscriberSince couple days ago, my charge simulations are not initializing. One of the files is attached. Here is the error message:Â
NEDA(process 0): Refinement limit exceeded for auto-refinement. The mesh is valid but may not be adequately refined.
NEDA(process 0): The program terminated due to an error: Initialization failed to converge charge update due to numerical failure. For instructions on how to troubleshoot this issue, please refer to this:Â online reference
NEDA(process 0): Error: there was an unknown parallel error. The error code is 9010, the process number is 0,Â
I tried any possible solution from your forum and this link online reference. I also tried to run on other PCs with higher computational resources. The issue is not resolved.  The weird thing is that all these simulations has been run quite well before. I would appreciate your quick reply.Â
Best,Â
NedaÂ
December 9, 2021 at 8:14 pmkghaffari
Ansys EmployeeHi Neda Thanks for reaching out. Unfortunately, we are not allowed to download attachments on the forum. If you could please share more information about your project I can comment on potential solutions. Specifically:
┬ÀInformation/Screenshots of your project (general structure, some of the solver and mesh settings, etc.).
┬ÀDo you currently have other versions of your projects that is running? If so, knowing the updates in your new project can be helpful.
┬ÀWhat version of the software are you using? Have you updated the software recently?
Thanks Khashayar
December 9, 2021 at 11:38 pmNeda_17
SubscriberHi Khashayar,
Thanks for the quick reply. I updated software few days ago, could it cause the problem?
My simulations include devices with and without back-reflector. It runs properly for simulations without back-reflector but not with back-reflector ones. In back-reflector case there is high generation rate within a thin layer.
I have access to premium support from the license purchased by my university, I emailed my problem with an attached simulation file. But premium support asked me to register and post my request here.
Thanks,
Neda
December 10, 2021 at 1:22 amNeda_17
I registered for support and shared my file there.
Thank you!
December 10, 2021 at 7:53 amkghaffari
Ansys EmployeeHi Neda Thank you for the update. We will get back to you there soon.
Best
December 31, 2021 at 9:43 amSutan
SubscriberHi Neda
I am experiencing the same error. Did you solve the problem?
December 31, 2021 at 9:36 pmNeda_17
SubscriberHi Sutan,
I deleted the new version and got back to use the previous version of Lumerical!
Hope this helps,
Neda
August 23, 2023 at 6:00 amcp li
Subscriber我也碰到了类似的问题。
DESKTOP-RJR1TNP(process 0): The program terminated due to an error: Initialization failed to converge charge update due to numerical failure. For instructions on how to troubleshoot this issue, please refer to this:Â online reference
DESKTOP-RJR1TNP(process 0): Error: there was an unknown parallel error. The error code is 9010, the process number is 0Viewing 7 reply threads- The topic ‘Charge simulation is not initializing’ is closed to new replies.
6750
1324
1087
