October 20, 2023 at 8:06 amhandonSubscriber
Like FDTD or RCWA, is there any resource configuration in CHARGE?
October 20, 2023 at 10:31 pmNiki PapachristouAnsys Employee
Hi Handon,
Our multi-physics simulation tools does not behave the same as FDTD. The process or threading option is not in the resource configuration.Â
You can change the threading options from within the solver.ÂYou can find more information here: Resource configuration for Lumerical solvers running with a single process
- The topic ‘CHARGE resources configuration’ is closed to new replies.
Ansys Innovation Space
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Help for qINTERCONNECT
- Trapezoidal ring
- Issues with getting result from interconnent analysis script
- How to measure transmission coefficients on a given plane .
- Topology Optimization Error
- Absorption cross-section of AuNR excited by prism-based TIR
591
544
524
366
