July 4, 2023 at 8:15 am
micali
SubscriberDear all,
does anyone know how can I fix this type of error?
_Â
Refinement limit exceeded for optical generation rate constraint. The mesh is valid but may not be adequately refined.
Thanks
July 4, 2023 at 10:53 pm
Guilin Sun
Ansys EmployeeThis is a common problem, meaning the optical generation is too large for the current mesh to resolve. Please check the power scale factor and make sure the injected power is proper for the small device. In addition you may need to increase the iteration limit etc. Please refer to
https://optics.ansys.com/hc/en-us/articles/360034918633-CHARGE-solver-Simulation-object
July 27, 2023 at 8:31 am
micali
SubscriberThanks for the reply.Â
However, I still don't understand why the injected power wouldn't be the proper one for the device. The optical generation rate is imported from FDTD simulations where the structure is exactly the same as CHARGE. Why should I scale it down?Â
Thanks in advanceÂ
July 28, 2023 at 8:32 pm
Guilin Sun
Ansys Employeeoh, yes. Common question.
In FDTD, the input power has been scaled to 1W. for small device it cannot bear such high optical absorption power. So we need to scale it down. Think this way, in the lab, how much power a detector can allow to be detected linearly? usually it is small. For high power lasers it will need bulk power meter.
- The topic ‘CHARGE – Mesh refinement’ is closed to new replies.
4678
1565
1386
1241
