January 14, 2025 at 4:21 pm
sara.bassil
SubscriberI am using python to simulate an electrooptic modulator in lithium niobate in the CHARGE solver in lumerical.
I used this example as an inspiration : https://optics.ansys.com/hc/en-us/articles/19435937674387-Thin-Film-Lithium-Niobate-Electro-Optic-Phase-ModulatorI get this problem :
The program terminated due to an error: Initialization failed to converge charge update due to numerical failure. For instructions on how to troubleshoot this issue, please refer to this: online reference
I tried all the advices that I could find in the online reference but nothing seems to work
I defined my charge region as follow :from DEVICE.user_inputs.user_simu_param import *from DEVICE.user_inputs.user_materiaux import *from DEVICE.waveguide_render import waveguide_drawdef add_charge_region(device):# Add the mesh and the FDE regionsdevice.addchargesolver()device.addchargemesh()# Adds the anode and cathodedevice.addelectricalcontact(name = "metal_left")device.addelectricalcontact(name = "metal_center")device.addelectricalcontact(name = "metal_right")v_metal_center = v_signalv_metal_right = 0# Monitorsdevice.addefieldmonitor(name = "electric_monitor")configuration = (("CHARGE",(("min edge length", min_edge_length),("max edge length", max_edge_length))),("CHARGE::mesh",(("x", 0),("y", 0),("z min", 0),("x span", wg_width),("z max", wg_height))),("simulation region",(("dimension", "2D Z-Normal"),("x", -(electrode_signal_width+electrodes_gap)/2),("z", 0),("y", 0),("x span", calcwindow_width),("y span", calcwindow_height),("background material", "my_SiO2"))),("CHARGE::boundary conditions::metal_left",(("bc mode", "steady state"),('sweep type', 'single'),('voltage', 0),("surface type", "solid"),("solid", "metal_left"))),("CHARGE::boundary conditions::metal_center",(("bc mode", "steady state"),('sweep type', 'single'),('voltage', v_metal_center),("surface type", "solid"),("solid", "metal_center"))),("CHARGE::electric_monitor",(("monitor type", 6),("x", 0.),("y", 0.),("z", 0.),("x span", calcwindow_width),("z span", calcwindow_height))),("CHARGE::boundary conditions::metal_right",(("bc mode", "steady state"),('sweep type', 'single'),('voltage', v_metal_right),("surface type", "solid"),("solid", "metal_right"))),)# Populate the waveguide simulation regionfor obj, parameters in configuration:for k, v in parameters:device.setnamed(obj, k, v)if(__name__=="__main__"):with lumapi.DEVICE(hide=True) as device:# Draw the waveguide structure using a custom functiondevice.redrawoff()waveguide_draw(device)# Draw the Simulation Regionadd_charge_region(device)device.save(EO_MODULATOR_DIRECTORY_WRITE_FILE + "\\eo_waveguide_render.ldev")My parameters are :
# 1. Simulation Region Parameterscalcwindow_width=25e-6calcwindow_length=8e-6calcwindow_height=8e-6# 2. Boxbox_length=8e-6background_material = 1.44# 3. Slabslab_length = box_lengthslab_height = 0.2e-6slab_width = 50e-6# 4. Waveguidespacer = 0.1e-6wg_height = 0.8e-6wg_width = 0.9e-6# 5. Electrodeselectrodes_height = 1.8e-6electrode_signal_width = 9.5e-6electrode_ground_width = 9.5e-6electrodes_gap = 5e-6v_signal = 1# 6. Mesh parametersmin_edge_length = 0.05e-6 # Minimum edge length for meshmax_edge_length = 1e-6 # Maximum edge length for meshmesh_enable = True # Enable meshmax_edge_length_mesh_override = 500e-9 # Maximum edge length for mesh override# 7. Feem parameterswavelength = 1.55e-6 # Wavelengthnum_modes = 6 # Number of modes# 8. Figuresmy_dpi = 96 # DPI for figuresr_13, r_33 = 9.6e-12, 30.9e-12eps_e, eps_o = 2.14 ** 2, 2.21 ** 2The second problem I have is in the definition of my lithium niobate :
#EM material propertydevice.addmodelmaterial()device.set("name", "my_LNOI")device.set("color",Vert)device.addemmaterialproperty("Dielectric")device.set("name","my_LNOI_em")device.select("materials::my_LNOI::my_LNOI_em")device.set("refractive index", 2.21)#CT material propertydevice.select("materials::my_LNOI")device.addctmaterialproperty("Semiconductor")device.set("name","my_LNOI_ct")device.select("materials::my_LNOI::my_LNOI_ct")# device.setnamed("anisotropy","Diagonal") =============> This leads to en error but it works when I use it in lumerical directly, do you know why ?# device.setnmed("dc permittivity xx",27.9)# device.setnamed("dc permittivity yy",44.3)# device.setnamed("dc permittivity zz",44.3)device.set("dc permittivity",27.9)device.set("work function",4)device.set("electronic.x.enabled",1)device.set("electronic.x.Eg.constant",7) -
January 15, 2025 at 3:46 pm
sara.bassil
SubscriberHi, I found the error :
It's in the definition of my lithium niobate material, up you can see how i defined it as a non anisotropic material but this seem to provoke the error of convergence!
Do you have an idea what may cause the lask of convergence in this definition ?
It would be so helpful! Thank you
Best,
Sara
January 15, 2025 at 4:32 pm
sara.bassil
SubscriberHi again,
I found the error : the box of trap-assisted (rsrh) was checked
So the last help I need is to define the anisotropy via python, is it possible ?
Thank you!!
Sara
January 22, 2025 at 8:30 pm
Amrita Pati
Ansys EmployeeHi Sara,
I apologize for the late reply. We are understaffed at the moment. I used python code to set the anisotropic permittivity and I wasn't able to recreate the issue. Here is the code I used:
device.switchtolayout();
device.select("materials::LiNbO3 semiconductor - X/Y cut (Lithium Niobate)::LiNbO3 semiconductor - X/Y cut (Lithium Niobate)");
device.set("anisotropy","Diagonal")
device.set("dc permittivity xx",10)
device.set("dc permittivity yy",20)
device.set("dc permittivity zz",20)Can you tell me which version of Lumerical are you using? Also, please use device.switchtolayout(); just before setting the material properties to make sure that the simulation is not in analysis mode. I noticed that if "Lock Mesh" is enabled then the file automatically goes to "Analysis Mode" even if you saved it in Layout Mode.
As a workaround, you may use the eval() function in Python to execute Lumerical code in the Script Prompt. Please let me know if this doesn't work too:
device.eval('set("anisotropy","Diagonal");')
device.eval('set("dc permittivity xx",30);')
device.eval('set("dc permittivity yy",40);')
device.eval('set("dc permittivity zz",50);')Regards,
Amrita -
January 28, 2025 at 4:16 pm
sara.bassil
SubscriberHi Amrita, no worries thank you for respoding,
I tried your suggestion but I get the "Failed to evaluate code" error
I am using the 2024 R1.3 version of Lumerical
Very weird..
Best,
Sara
February 3, 2025 at 3:04 pm
sara.bassil
SubscriberThe error I get when I use these lines of code :
# LNOI=np.array([2.21,2.14,2.21])#EM material propertydevice.addmodelmaterial()device.set("name", "my_LNOI")device.set("color",Vert)device.addemmaterialproperty("Dielectric")device.set("name","my_LNOI_em")device.select("materials::my_LNOI::my_LNOI_em")device.set("refractive index", 2.21)#CT material propertydevice.select("materials::my_LNOI")device.addctmaterialproperty("Semiconductor")device.set("name","my_LNOI_ct")device.select("materials::my_LNOI::my_LNOI_ct")device.set("anisotropy","Diagonal")# device.set("dc permittivity",27.9)device.set("dc permittivity xx",27.9)device.set("dc permittivity yy",44.3)device.set("dc permittivity zz",44.3)Concerns the "anisotropy" line :
raise LumApiError(message)
lumapi.LumApiError: 'in set, the requested property was not found'When I try : device.set("anisotropy","None") I get the same error !
Can I control the anisotropy of the material in this version of Lumerical with python ?
Best,
Sara
February 4, 2025 at 6:38 pm
Amrita Pati
Sorry, I couldn't get back to you earlier. I was traveling for work last week. The anistropy feature in CHARGE was introduced in 2023 R1.2. So, in principle it should work. But it is possible that it wasn't accessible through script. I serached internally and couldn't find anything specfic to when the script version was implemented. I will check with the R&D team. Are you able to set it from Lumerical directly (using .lsf)? It looks like the property wasn't accessible through the script at all, so I would not expect it to work.
Amrita -
February 5, 2025 at 7:38 am
sara.bassil
No worries, thank you for your assistance, it's a big help!
Yes, I am able to set it in Lumerical directly using lsf, that's why I thought that it will not be a problem setting it with python
Best,
Sara
6535
1311
