March 8, 2022 at 3:14 pm
Antimesher
SubscriberI can't find a way to change the units in ANSYS Fluent 2021 R2 after importing the geometry from Solidworks --> design modeler --> Fluent meshing. It's currently set to metres and won't allow me to change it to mm (see attached image). Is there a reason for this and how can I rectify it?
March 9, 2022 at 10:20 amKeyur Kanade
Ansys EmployeeYou will need to edit this step using Revert and Edit option at bottom. Then you can change it.
Please go through help manual for more details
Regards Keyur
March 9, 2022 at 10:32 amAntimesher
SubscriberHi Thank you for your reply. I did use the Revert and Edit option but it still does not allow me to change the units - it's still greyed out; it only allows me to change the file I upload, but not the file format or units
March 9, 2022 at 1:31 pmKarthik Remella
AdministratorHi If you are using WorkBench, you will have to change the units from WorkBench. Right-Click on Fluent Meshing cell in WB and go to properties. You should be able to make the change there.
Karthik
March 11, 2022 at 2:00 pmAntimesher
SubscriberThank you so much! exactly what I needed :)
Viewing 4 reply threads- The topic ‘Change units in ANSYS Fluent mesher 2021 R2’ is closed to new replies.
Innovation SpaceTrending discussions- JACOBI Convergence Issue in ANSYS AQWA
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
Top Contributors-
4597
1495
1386
1209
