February 27, 2019 at 5:51 pm
jainam3112
Subscriberi am currently doing thermal - transient analysis in ansys apdl. i want to change temperature scales to my desire ranges and here as per picture you can see that we are getting 9 temperature range but as per my requirment i want to add 12 temperature scale . so, anyone know how to solve this problem ,then please help me.
thank u !
March 5, 2019 at 7:49 pm
mrife
Ansys EmployeeJainam3112
Since you are using the MAPDL GUI use the following: PlotCtrls -> Style -> Contours. Then most likely Uniform Contours (not sure if you want uniform or non-uniform spacing on the contour plot) and change the number of contours to 12. And replot.
Mike
- The topic ‘change temperature scale in ansys apdl’ is closed to new replies.
