Preprocessing
Preprocessing
Change mesh type
    • DineshKanesan123
      Hi, would like to ask on how to change the mesh type from Type 1 (Fig1) to Type 2 (Fig2).
      Type 1 looks like you've used the "hex-dominant" mesh method which is a really bad idea for CFD. This differs from a hex dominant (ie all hex) mesh formed from sweep or similar.  Type 2 is referred to as an O-grid or butterfly mesh and isn't used much anymore as sweep and pave are much more time efficient.
    • DineshKanesan123
      Thanks alot
    • DineshKanesan123
      Could you please guide me on how to generate the O-grid mesh? Is the generated in the attached figure correct?
    • DineshKanesan123
      It's not available in ANSYS meshing or Fluent meshing.  It might still be in ICEM meshing, but I don't know.
      As was mentioned above, O-grid mesh doesn't provide the best solution quality relative to other mesh shapes.  Solutions should be mesh independent. When that is true, it doesn't matter what shape the mesh is.
      If you want to persist, then for ANSYS meshing, you have to slice up the geometry to make the 5 pieces of solid to mesh separately, the center "square" and the four outer pieces with the circular arcs and straight radial lines.
    • DineshKanesan123
      Thanks for the response. What mesh type provides the best solution quality for capturing erosion in pipes (near wall treatment) ?
      In ANSYS meshing, use a mesh control called Inflation to put many thin elements near the wall.  Your pipe should be a sweepable body, so use a mesh method of Sweep. Pick the end face as the source of the sweep and add a Sizing mesh control on the circular edge of that face to set the element size.  Also, on the Mesh Details window, type an element size to limit how large the elements can get at the center of the pipe. In Mesh Details, you can turn on Element Quality and plot various element quality metrics.
      I don't know as much about Fluent meshing, but that has similar capabilities.
Viewing 7 reply threads
  • The topic ‘Change mesh type’ is closed to new replies.
