Ansys Free Student Software
Change from student licence to academic licence
    • cujhg
      I used to use the free student version from Ansys. As I've run into the limitation of 512000 Nodes I want to switch to my university's academic licence. Is that possible or do I have to reinstall Ansys from the ground up?
      Thanks,
      Clemens
    • ANSYS_MMadore
      You will need to install the full Ansys package.
    • drwatts9721
      How can we go about installing the full Package? I also have the student version and would like to switch over to the full package. I cannot find any location on the website for installing the full package.
      The full package is on the Customer Portal, https://support.ansys.com/Home/HomePage under downloads. You'll need to register, and if you have any problems please use the Help on there: we can't do anything from this side.
      Please make sure you completely uninstall the Student version(s) from your machine BEFORE installing the full version. The licence managers do not work well together. You'll also need to either have a local licence or see the University system.
  • The topic ‘Change from student licence to academic licence’ is closed to new replies.
