June 12, 2019 at 11:57 am
Johnson
Subscriber Hi all,
getting started with APDL Commands in Workbench, I tried to change the element type:
- I inserted a command block under the geometry where I want to change the element
- I used the command: "ET,matid,SOLID186"
Now it says "ELEMENT TYPEÂ Â 20 IS SOLID186. KEYOPT(2) IS ALREADY SET AS SUGGESTED." in my solver output.
But Workbench is showing a different element (SOLID185) after the mesh generation.
How can I make sure that Ansys follows my command?
Greetings
Johnson
June 12, 2019 at 3:00 pm
sk_cheah
SubscriberHi Johnson,
A command snippet with ET, matid, 186 should do the trick. As SOLID186 has mid-side nodes, make sure your mesh reflects that (Element Order: Quadratic). Solid185 has no mid-side nodes.Â
Kind regards,
Jason
- The topic ‘Change Element type using APDL command’ is closed to new replies.
1330
1097
