CFX-Solver error
    • Walaikorn
      Hello everyone!
      I have been practiced using Ansys software for 2 months.
      Now, I am trying to simulation jet cross flow and I have the problem in the step of calculation process in CFX-Solver. The error was showed in this picture.
      I have already checked and regenerated meshing but it's not work. For the recommend Of changing the parameter of vector parallel tolerance, I haven't seen and found where is this setting. If you know that, please help me to fix it.
      I think that the problem that the symmetry is not parallel to the plane is about this points (In the pictures) because the symmetry vectors are not parallel to the others.
      Do you have any idea to help me solve this problem?
      Thank you in advance
    • raul.raghav
      Did you create the mesh using ICEM-CFD? Can you share the workbench archive file so that we can take a look at it?
    • Walaikorn
      Thank you for your reply.
      I didn't use workbench in this simulation. I used ICEM-CFD to create mesh, this is the simple meshing and the mesh quality is equal 1(maximum).
      These pictures are the step of meshing.
      Geometry
      Blocking
      Meshing
      Meshing (top)
      Meshing (front)
      Mesh Quality
      Process
         I create geometry and meshing in ICEM-CFD --> define parameters by CFX-Pre --> calculation by CFX-Solver --> postprocessing in CFD-Post
      If you need more information, please let me know.
      Thank you so much.
    • raul.raghav
      I could help you better if I had access to the icem-cfd project. Can you zip the project folder and attach it here?
      If you'd like to give it a shot, I have a couple of suggestions which might be of help to you:
      1. The points in your geometry might not be exactly located on the symmetry plane, due to which the CFX shows "symmetry-vectors" that are not parallel. When the blocking is complete and it is projected on to the symmetry plane, it is not exactly projected on the symmetry plane due to which you might have the issue. You might want to associate faces with the surfaces manually and then try exporting it to CFX.
      2. You'd have to rebuild the surfaces with a lower tolerance and then try the blocking.
    • Walaikorn
      Thank you very much for your recommend. I appreciated that.
      I will recheck again follow by your suggestion.
      One more question, how can I setting the tolerance in the program?
      Thank you in advance.
      Walaikorn
    • raul.raghav
      Walaikorn, I was referring to the tolerance when you build surfaces in ICEM-CFD (see attached screenshot).
      However, I have a feeling you wanted to know about the "vector parallel tolerance" in CFX-Pre. It can be found under "Expert Parameters". See following screenshots:
    • Walaikorn
      I am so appreciated for your helping.
      Thank you very much.
Viewing 6 reply threads
  • The topic ‘CFX-Solver error’ is closed to new replies.
