September 29, 2019 at 1:16 pm
DenB
SubscriberHappens on Ansys 19 R2. When I complete an fine working mesh and try to open it in cfx-pre, it won't recognize the mesh file in designated location even though it's there (see attached).
Den
Edit: To add to this, it's also not possible to import mesh file when opening pre manually. When I try to browse the designated file location it looks empty...
September 30, 2019 at 2:33 am
yangyee
SubscriberMay be the file path problem?
September 30, 2019 at 11:53 am
DenB
SubscriberToday it worked on 7/8th try... I don't have a clue, i did nothing different and now pre decides it can see the file in the same location.
Edit: Well not really, it does crash after few edits i do on the domain
- The topic ‘CFX-PRE Won’t Open Mesh File’ is closed to new replies.
