May 21, 2026 at 5:02 am
filipegicasado
SubscriberHello, I'm having trouble running my simulation. The following message is appearing: "Failed to update the Solution component in CFX. The solver failed with a non-zero exit code of: 1". I'm analyzing wind loads on buildings, and I'm currently performing a wind load at a 90° angle to the building. However, the error keeps appearing during the simulation, and I don't know how to solve it anymore. I've already tried renaming the files, uninstalling and reinstalling Ansys. I'm using the student version for the analysis.Below is a Google Drive link to access the project.
https://drive.google.com/drive/folders/1mV_cOBWLN_19u4RjUTTPOuCy2BbepIMq?usp=drive_link
Please, i need help!!! -
May 21, 2026 at 6:42 am
filipegicasado
Subscriber This run of the CFX 2025 R2.04 Solver started at 02:41:32 on 21 May
 2026 by user MASSA on MASSA-PC (intel_xeon64.sse2_winnt) using the
 command:
 "C:\Program Files\ANSYS Inc\ANSYS Student\v252\CFX\bin\perllib\cfx5solve.pl"
  -batch -ccl runInput.ccl -fullname CFX_007
 2025 R2.04
 Point Releases and Patches installed:
 Discovery 2025 R2
 Core WB Files 2025 R2
 optiSLang 2025 R2
 CFX (includes CFD-Post) 2025 R2
 Chemkin 2025 R2
 EnSight 2025 R2
 FENSAP-ICE 2025 R2
 Fluent (includes CFD-Post) 2025 R2
 Polyflow (includes CFD-Post) 2025 R2
 Forte (includes EnSight) 2025 R2
 Rocky 2025 R2
 TurboGrid 2025 R2
 ACIS Geometry Interface 2025 R2
 AutoCAD Geometry Interface 2025 R2
 Catia, Version 4 Geometry Interface 2025 R2
 Catia, Version 5 Geometry Interface 2025 R2
 Catia, Version 6 Geometry Interface 2025 R2
 Creo Elements/Direct Modeling Geometry Interface 2025 R2
 Creo Parametric Geometry Interface 2025 R2
 Inventor Geometry Interface 2025 R2
 JTOpen Geometry Interface 2025 R2
 NX Geometry Interface 2025 R2
 Parasolid Geometry Interface  2025 R2
 Solid Edge Geometry Interface 2025 R2
 SOLIDWORKS Geometry Interface 2025 R2
 Speos 2025 R2
 SpaceClaim 2025 R2
 Speos RPC 2025 R2
 Zemax OpticStudio 2025 R2
 Dynamic Reporting 2025 R2
 Aqwa 2025 R2
 Autodyn 2025 R2
 Material Calibration App 2025 R2
 Mechanical Products 2025 R2
 Motion 2025 R2
 Academic Student 2025 R2
 Setting up CFX Solver run ...
 |           CFX Command Language for Run           |
 LIBRARY:
  MATERIAL: Air at 25 C
   Material Description = Air at 25 C and 1 atm (dry)
   Material Group = Air Data,Constant Property Gases
   Option = Pure Substance
   Thermodynamic State = Gas
   PROPERTIES:
    Option = General Material
    EQUATION OF STATE:
     Density = 1.226 [kg m^-3]
     Molar Mass = 28.96 [kg kmol^-1]
     Option = Value
    END
    SPECIFIC HEAT CAPACITY:
     Option = Value
     Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
     Specific Heat Type = Constant Pressure
    END
    REFERENCE STATE:
     Option = Specified Point
     Reference Pressure = 1 [atm]
     Reference Specific Enthalpy = 0. [J/kg]
     Reference Specific Entropy = 0. [J/kg/K]
     Reference Temperature = 25 [C]
    END
    DYNAMIC VISCOSITY:
     Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
     Option = Value
    END
    THERMAL CONDUCTIVITY:
     Option = Value
     Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
    END
    ABSORPTION COEFFICIENT:
     Absorption Coefficient = 0.01 [m^-1]
     Option = Value
    END
    SCATTERING COEFFICIENT:
     Option = Value
     Scattering Coefficient = 0.0 [m^-1]
    END
    REFRACTIVE INDEX:
     Option = Value
     Refractive Index = 1.0 [m m^-1]
    END
    THERMAL EXPANSIVITY:
     Option = Value
     Thermal Expansivity = 0.003356 [K^-1]
    END
   END
  END
 END
 FLOW: Flow Analysis 1
  SOLUTION UNITS:
   Angle Units = [rad]
   Length Units = [m]
   Mass Units = [kg]
   Solid Angle Units = [sr]
   Temperature Units = [K]
   Time Units = [s]
  END
  ANALYSIS TYPE:
   Option = Steady State
   EXTERNAL SOLVER COUPLING:
    Option = None
   END
  END
  DOMAIN: Default Domain
   Coord Frame = Coord 0
   Domain Type = Fluid
   Location = B75
   BOUNDARY: CASA
    Boundary Type = WALL
    Location = F34.75,F35.75,F36.75,F37.75,F38.75,F39.75,F40.75,F41.75
    BOUNDARY CONDITIONS:
     MASS AND MOMENTUM:
      Option = No Slip Wall
     END
     WALL ROUGHNESS:
      Option = Rough Wall
      Sand Grain Roughness Height = 0.05 [m]
     END
    END
   END
   BOUNDARY: chao
    Location = F28.75
     MASS AND MOMENTUM:
     END
     WALL ROUGHNESS:
      Option = Rough Wall
     END
    END
   END
   BOUNDARY: inlet
    Boundary Type = INLET
    Location = F33.75
     FLOW REGIME:
      Option = Subsonic
     END
     MASS AND MOMENTUM:
      Normal Speed = 29.09 [m s^-1]
      Option = Normal Speed
     END
     TURBULENCE:
      Option = Medium Intensity and Eddy Viscosity Ratio
     END
    END
   END
   BOUNDARY: outlat
    Boundary Type = OUTLET
    Location = F31.75
     FLOW REGIME:
      Option = Subsonic
     END
     MASS AND MOMENTUM:
      Option = Average Static Pressure
      Pressure Profile Blend = 0.05
      Relative Pressure = 0 [Pa]
     END
     PRESSURE AVERAGING:
      Option = Average Over Whole Outlet
     END
    END
   END
   BOUNDARY: parede
    Location = F29.75,F30.75,F32.75
     MASS AND MOMENTUM:
     END
     WALL ROUGHNESS:
      Option = Smooth Wall
     END
    END
   END
   DOMAIN MODELS:
    BUOYANCY MODEL:
     Option = Non Buoyant
    END
    DOMAIN MOTION:
     Option = Stationary
    END
    MESH DEFORMATION:
     Option = None
    END
    REFERENCE PRESSURE:
    END
   END
   FLUID DEFINITION: Fluid 1
    Material = Air at 25 C
    Option = Material Library
    MORPHOLOGY:
     Option = Continuous Fluid
    END
   END
   FLUID MODELS:
    COMBUSTION MODEL:
     Option = None
    END
    HEAT TRANSFER MODEL:
     Fluid Temperature = 25 [C]
     Option = Isothermal
    END
    THERMAL RADIATION MODEL:
     Option = None
    END
    TURBULENCE MODEL:
     Option = SST
    END
    TURBULENT WALL FUNCTIONS:
     Option = Automatic
    END
   END
  END
  OUTPUT CONTROL:
   RESULTS:
    File Compression Level = Default
    Option = Standard
   END
  END
  SOLVER CONTROL:
   Turbulence Numerics = First Order
   ADVECTION SCHEME:
    Option = High Resolution
   END
   CONVERGENCE CONTROL:
    Length Scale Option = Conservative
    Maximum Number of Iterations = 500
    Minimum Number of Iterations = 1
    Timescale Control = Auto Timescale
    Timescale Factor = 1.0
   END
   CONVERGENCE CRITERIA:
    Residual Target = 1.E-4
    Residual Type = RMS
   END
   DYNAMIC MODEL CONTROL:
    Global Dynamic Model Control = On
   END
   INTERRUPT CONTROL:
    Option = Any Interrupt
    CONVERGENCE CONDITIONS:
     Option = Default Conditions
    END
   END
  END
 END
 COMMAND FILE:
  Version = 25.2
  Results Version = 25.2
 END
 SIMULATION CONTROL:
  EXECUTION CONTROL:
   EXECUTABLE SELECTION:
    Double Precision = No
    Large Problem = No
   END
   INTERPOLATOR STEP CONTROL:
    Runtime Priority = Standard
    MEMORY CONTROL:
     Memory Allocation Factor = 1.0
     Option = Model Based
    END
   END
   LICENSE CONTROL:
    Capability Level = Automatic
    HPC License = Automatic
   END
   PARALLEL HOST LIBRARY:
    HOST DEFINITION: massapc
     Remote Host Name = MASSA-PC
     Installation Root = C:\Program Files\ANSYS Inc\ANSYS Student\v%v\CFX
     Host Architecture String = winnt-amd64
    END
   END
   RUN DEFINITION:
    Run Mode = Full
    Solver Input File = CFX.def
    Solver Results File = H:/Faculdade Lipe/Faculdade Lipe \
     oficial/2026-1/TCC2/Projetos_Ansys_TCC_2/casinha \
     90graus_pending/dp0_CFX_Solution/CFX_007.res
   END
   SOLVER STEP CONTROL:
    MEMORY CONTROL:
    END
    PARALLEL ENVIRONMENT:
     Maximum Number of Processes = 1
     Start Method = Serial
    END
   END
  END
 END
 |                Solver                |
ÂÂ
 |            ANSYS(R) CFX(R) Solver            |
 | 2025 R2.04                             |
 | Build 25.2 2025-05-19T16:15:13.627102                |
 | Mon May 19 17:14:36 GMTDT 2025                   |
 |             Executable Attributes            |
 |      single-64bit-int32-archfort-optimised-std-lcomp      |
 | (C) 1996-2025 ANSYS, Inc.                      |
 | All rights reserved. Unauthorized use, distribution or duplication |
 | is prohibited. This product is subject to U.S. laws governing    |
 | export and re-export. For full Legal Notice, see documentation.   |
 +--------------------------------------------------------------------+Â
 |          Job Information at Start of Run          |
 +--------------------------------------------------------------------+ Run mode:    serial run
 Host computer:  MASSA-PC (PID:14876)
 Job started:   Thu May 21 02:41:35 2026
 |             License Information             |
 +--------------------------------------------------------------------+ License Cap:   ANSYS CFD Solver
 License ID:   MASSA-PC-MASSA-3740-001772 INFO: You are using an academic student license which enables meshesÂ
    up to 1000000 vertices. INFO: Your license enables 4-way parallel execution.
    For faster simulations, please start the application with the
    appropriate parallel options.
 |     Initial Memory Allocation  (Actual usage may vary)     |
 +--------------------------------------------------------------------+      | Real    | Integer   | Character | Logical  | Double
 Mwords   |    57.58 |    22.36 |    9.32 |   0.12 |   0.91
 Mbytes   |   219.63 |    85.30 |    8.89 |   0.46 |   6.93
 |       Host Memory Information (Mbytes): Solver         |
 |      Host      |   System   |  Allocated   |  %   |
 | MASSA-PC         |   16326.93  |    321.21  |  1.97 |
 |            Topology Simplification            |
 |            ****** Warning ******             |
 | Topology simplification is activated with the following       |
 | restrictions:                            |
 | - Mesh regions referenced only within User Fortran and NOT     |
 |  in the command file will cause the solver to stop.        |
 | - The solver will stop during any "Edit Run in Progress" step    |
 |  if new 2D regions are referenced.                 |
 |              Mesh Statistics              |
 | Domain Name      | Orthog. Angle | Exp. Factor  | Aspect Ratio |
 |            | Minimum [deg] |  Maximum   |   Maximum  |
 | Default Domain    |     6.9  ! |    896  ! |    112 ok |
 |            |  %!  %ok  %OK | %!  %ok  %OK | %!  %ok  %OK |
 | Default Domain    |  <1  <1  100 | <1   1  99 |  0  <1  100 |
 +----------------------+---------------+--------------+--------------+ Domain Name : Default Domain
   Total Number of Nodes                 =    143578
   Total Number of Elements               =    805254
     Total Number of Tetrahedrons           =    802004
     Total Number of Prisms              =     2851
     Total Number of Pyramids             =     399   Total Number of Faces                 =    30170
 |           Average Scale Information            |
 +--------------------------------------------------------------------+ Domain Name : Default Domain
   Global Length                     = 1.0767E+02
   Minimum Extent                     = 5.7658E+01
   Maximum Extent                     = 2.0420E+02
   Density                        = 1.2260E+00
   Dynamic Viscosity                   = 1.8310E-05
   Velocity                        = 2.9090E+01
   Advection Time                     = 3.7014E+00
   Reynolds Number                    = 2.0973E+08 +--------------------------------------------------------------------+
 |         Checking for Isolated Fluid Regions         |
 | ERROR #001100279 has occurred in subroutine ErrAction.       |
 | Message:                              |
 | SYMASS_ZONE_EL : The solver ran out of temporary space while buil- |
 | ding a linked list for a domain.  Try setting the expert paramete- |
 | r "topology estimate factor" to a value greater than 1.0.  Values  |
 | higher than 1.2 should not be necessary.              |
 |           Writing crash recovery file           |
 Details of error:-
 Error detected by routine POPDIRÂ
 CRESLT = ILEG
 Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES +--------------------------------------------------------------------+
 |         An error has occurred in cfx5solve:         |
 | The ANSYS CFX solver exited with return code 1.  No results file  |
 | has been created.                          |
 +--------------------------------------------------------------------+End of solution stage.
 |                Warning!                |
 | The ANSYS CFX Solver has written a crash recovery file.  This file |
 | has been saved as H:/Faculdade Lipe/Faculdade Lipe         |
 | oficial/2026-1/TCC2/Projetos_Ansys_TCC_2/casinha          |
 | 90graus_pending/dp0_CFX_Solution/CFX_007.res.err and may be an aid |
 | to diagnosing the problem or restarting the run.  More details   |
 | should be available in the solver output section of the output   |
 | file.  Note that a lock file was left for the crash file when the  |
 | solver exited, and so it is probably incomplete.          |
 | The following user files have been saved in the directory      |
 | H:/Faculdade Lipe/Faculdade Lipe                  |
 | 90graus_pending/dp0_CFX_Solution/CFX_007:              |
 | trace, mon                             |
 | For CFX runs launched from Workbench, the final locations of    |
 | directories and files generated may differ from those shown.    |
THIS IS A LAST RELATORYÂ
6510
