September 19, 2022 at 7:08 am
eric1234598765
SubscriberHi,
I want to know if CFX is able to solve the energy equation of porous as thermal equilibrium, since " CFX theory guide" has mentioned effective thermal conducitivty. Unfortunately, the guide doesn't explain what that term is, which make me unable to recoongize the equation below as thermal equlilbrium equation.
I've already known the effective thermal conducitivty formula in Fluent, which is the weighted of porosity of fluid phases and solid phases.
Therefore, please help me to verify the effective thermal conducitivty in CFX.
BTW, please also guide me to activate thermal equilibrium model if possible. (Instead of non-equilibrium)
Thanks,
Eric
September 19, 2022 at 2:30 pm
DrAmine
Ansys EmployeeÂ
Just run the fluid and remove the solid if you want to get it equilibirum.
September 19, 2022 at 4:47 pm
eric1234598765
SubscriberHi, DrAmine
Thanks for guiding me to activate thermal equilibrium model!
Although the definition of effective thermal conductivity in CFX may be the same of that in Fluent, which is :
where gama and lambda are porosity and conductivity, and subscript f and s are fluid and solid, respectively.
I'd like someone familar to CFX porous to clarify the effective thermal conductivity in CFX, just in case.
Thanks,
Eric,
September 20, 2022 at 6:35 am
DrAmine
Ansys EmployeeI am familiar with Ansys CFX.
September 20, 2022 at 7:45 am
DrAmine
Ansys EmployeeCreate your effective thermal conductivity with an expression and use that for the fluid property.
September 20, 2022 at 2:28 pm
eric1234598765
Thanks, that was a helpful information.?
- The topic ‘[CFX] Definition of effective thermal conductivity in porous zone’ is closed to new replies.
5649
1885
1404
1303
