January 23, 2020 at 4:29 pm
Chaitanya
SubscriberWhat type of cell zone conditions, boundary conditions can be given to a heat pipe with wick structure? -
January 23, 2020 at 5:20 pm
Forum ModeratorWalls and fluid would be a good start. Maybe try reading up on the models in Fluent and explain what the physics is doing?
January 23, 2020 at 5:34 pm
Chaitanya
SubscriberSir,I am confused about the capillary wick structure and the conditions at the solid liquid interface. -
January 24, 2020 at 11:20 am
Forum ModeratorConfused by the modelling or the physical heat sink?Â
January 24, 2020 at 11:50 am
Chaitanya
SubscriberThank you sir 1. About the modelling of capillary wick structure. 2. Phase change of fluid and return of the fluid to the evaporator from the condenser section. -
January 24, 2020 at 3:31 pm
Forum ModeratorRight, do you plan on modelling the wick material precisely or using a porous media? Heat pipes are not simple systems to model so you're going to need to fully understand the multiphase models, phase change and how the wick interacts with these.Â
November 30, 2021 at 12:07 pm
VBS
Subscriber.Sir, modelling wick material using a porous media
November 30, 2021 at 12:20 pm
ErKo
Ansys Employee.VBS
Not sure what the question is - this is an old post, so please open up a new one in the fluids forum (this is for cad and 3d design). This one is closed now.
Fluids — Ansys Learning Forum
thank you
Erik
Viewing 7 reply threads
- The topic ‘Cfd simulation of heat pipe with wick’ is closed to new replies.
