April 25, 2020 at 6:50 pm
Bran
SubscriberHello,
I am using CFD-Post for my post processing to generate iso-surfaces for temperatures. My issue is that I cannot create iso-surfaces for a range, I must create each iso-surface individually. I wanted to create iso-surfaces from 25C to 40C so with the software, I must generate 15 separate iso-surfaces starting from 25 and ending with 40. The problem is that CFD post does not generate isosurfaces for the temperatures reading 25.1C, 25.2C, it is strictly 25C. So I am coming across problems generating isosurfaces. How can I generate iso-surfaces for the range of 25C to 40C?
Thanks.
April 27, 2020 at 11:03 am
Forum ModeratorOne at a time manually, or use a script.Â
- The topic ‘CFD-Post iso-surfaces’ is closed to new replies.
