CFD-Post error in Keyframe Animation
    • Jamasp
      Hello all,
      I'm trying to make a video in Keyframe Animation by having CFD solution from Fluent and FEA from Mechanical. When I load CFD solutions there is no problem but when I add the solution from Mechanical, I'm getting an error in Keyframe Animation.It would be great if you help me out to resolve this problem.
      Thanks,
      Jimmy
    • Keyur Kanade
      Did you define keyframe before loading mechanical results?
      Load fluids and mechanical results first and then try to define keyframe.
      Keyur
    • Jamasp
      Hello Keyur,
      Yes, I first imported the results of both fluid and solid and then define the keyframe. What is the cause of this error?!
      Best,
      Jimmy
    • Keyur Kanade
      Error shows some zone name. It also shows that some zone has some special character.
      Please avoid using any special character.
      Keyur
    • Jamasp
      The error seems to be from Mechanical. I have multiple zones in ANSYS Mechanical and they don't have any specific. Can you show me how can I make sure the zones have no specific character?
      Thank you
      Jimmy
    • Keyur Kanade
      I am from fluids. Let me check if somebody from mech reply.
      Keyur
    • Jamasp
      Thank you.
      Jimmy
    • Jamasp
      Hi Keyur,
      It works when I have one single solid body. It gives me that error for multiple solid bodies!
      Thanks,
      Jimmy
      Check the zone names, what can you see?
    • Jamasp
      Where do I need to check the names? In mechanical, the names are OK. Where can I check in the output file?
Viewing 9 reply threads
  • The topic ‘CFD-Post error in Keyframe Animation’ is closed to new replies.
